I would be interested to know how fellow weavers might go about adding two lines to either side of a small piece of text. Responsively (though not necessarily responsibly
This is perfect for you…
https://stacks4stacks.com/rulestack/
Think that only works for Font Awesome Icons.
@LSPhoto
Thanks for the heads up Lisa.
I’ve had a play and unfortunately I think @teefers is correct in the Font Awesome limitations.
Doubtless there’s a way to substitute html text for the icon class but that’s above my pay grade.
Usefull nonetheless.
@rolisize That’s got potential.
I’ve just had a play and it will take a little learning.
(About time I learnt to use BWD stacks having said that).
A project for when I have a spare hour.
Any alternatives meantime still appreciated.
If you use Foundry then the divider stack offers this option.
This will work on about 90% of browsers. You can be the first on your block to use CSS Grid:
- Get CSS-box (free from Joe Workman).
- Place the CSS-box on the page, put the class name
wrapitin as the class name. - Put a standard stacks header in the CSS-box( set to h3).
Add the following code to CSS for the page:
.wrapit h3 {
grid-column: 1 / -1;
display: grid;
grid-template-columns: 1fr auto 1fr;
grid-gap: 20px;
align-items: center;
.wrapit h3::before {
display: block;
content: '';
height: 5px;
background: linear-gradient(to left, black, transparent);
.wrapit h3::after {
display: block;
content: '';
height: 5px;
background: linear-gradient(to right, black, transparent);
And you get this gradient line:
@teefers
That works well. Thanks Doug, I’m obliged.
Glad it works for you.
You can change the line color if you like, on this two statements:
Change the black To any CSS color.
To change the line width just change the two height Statements.
Another option would be to use a three column stack, put the text in the middle and ad two “rules” as a simple png image file. This would give you the flexibility to use graphic flourishes instead of rules if you so wished. But if the png file was a simple horizontal black line, it would responsively fill the space available.
