Building a footer
I want to build a footer with two or three different columns that are completely separate from each other ie.
Whatever I try flex grid or container the spacing is mirrored on all. I want a row of 7 evenly spaced text one side, with part text in two columns on the 2nd column with a picture beneath. As soon as the picture goes in the spacing on the 1st column opens up ruining the layout. How do I achieve this please?
do you have an image or a live example of what you’re trying to achieve (perhaps you’ve seen this on another site)? We can then whip up an example for you :slight_smile:
Thank you Ben here is a Link to the url
and it’s obviously at the bottom](https://www.the-olive-tree-church-wembury.co.uk)
attempt to replicate, above mobile the split is 1 - 1, mobile it is 4 - 2
not sure what ratios you wanted, no real spacing applied, grids have different background colors to show them, you could have 7 - 4, or 5 - 4 for mobile
just with grid not used flex
1-1 all screen
Many thanks for your quick response Steve, unfortunately this one I can’t quite get my head around the settings used.
It would appear that the lefthand column is made up of a grid 2 containers and 2 text elements the right hand column is container inside the 2nd grid column and text for the heading but unsure how the responsive 2 columns are made up I have tried the container as a a 2 column grid but it just seems to produce one drop zone, I have tried 2 grids but they don’t collapse on top of its neighbouring grid. the Container and the image I guess look straightforward.
Graham
I’ll post the file here when I am at my laptop
This is just one way, not sure exactly how you would want the ratios each side
The change is made from mobile to sm
this is just 2 cols / 2 cols with the grids I have written ‘next screen 1’ and ‘next screen 2’ , both switching from 1 col to 2 cols, they then change row position
I didn’t need to blue dot as many as I did, that was just for me to adjust col ratio’s
Not sure if this makes sense, I could create a video of how I did this
grid
elementsapp://downloadDocument/mGPl2BMUUpCI
flex. not finished, need to sort out image
elementsapp://downloadDocument/PNxGyhz2qJDI
this is the download
flex version only spent 5 mins so not finished
ok adjusted image, not checked anymore that this, so may have issues?
updated flex
elementsapp://downloadDocument/tVa5GhxS2EnH
Steve W, Thank You So Much, you have been a brilliant help, and so patient and thorough.
May God Bless you abundantly
Graham
