Would like to center the panel headings if possible. Thanks.
Hi, do you have a link to a page showing the accordion stack whose panel heading you would like to center?
The following CSS will center the headings
text-align: center;
If you put this in the page inspector it will center align all the headings for every accordion on your page. In site-wide CSS is will affect every accordion instance on your site.
If you want to select just one then you should drop it into a cssbox stack (or similar) and give it a unique class e.g. ```.myAccordion```
The above CSS will then become
```.myAccordion .accordion-navigation>a{
text-align: center;
Thanks! That worked great!
