Is there a simple way to change the following: “Select Blog” to just “Select” Or “Select Class” ? O.r it would even work better if I could change the word blog to class in every instance. I am using Armadillo to allow clients to create their own classes and taking out or changing blog might be less confusing. Anyone have a snippet of CMS that I can use in settings under Custom Css? ![]()
