Just wondering if there isa way of changing the Blog Post Title font size.
It can’t be that I need to purchase
Fonts Pro stack to make the change surely?Cheers!
Not totally sure but have you tried Site Styles (if this is a Foundation site)?
@jabostick is kind of correct, that title takes on the h3 size of the theme that you are using. Sure it can be switched with some CSS, but we would need a link to help you with that.
Hi both
That has lead me to exactly what I needed! Thanks for your help. I simply adjusted the H3 settings and all is now good!
Cheers
