CMS help selecting which one
Watch the getting started videos. They implement Total CMS inside an existing RapidWeaver project. https://www.youtube.com/watch?v=417AUiUIIns&list=PLAwL8Kl4ijMrL5RCNCwHOuWUwYZFKOO_J&index=1
@joeworkman
Thank you. I couldn’t find those.
I don’t want to push you off the suggestions already made, but Seydesign’s sentry, which is super basic and easy to set up sounds like what you need. I’ve used/own, Armadillo, Sentry, TotalCMS, (but not Easy CMS). For simple sites, I love Sentry - easy light weight set up. For a blog central site, Armadillo is quite nice, and still allows for other content sections to be updated. The interface is straight forward. TotalCMS is for a complete management system, and requires a bit more effort on the setup side. The benefit is you can do whatever the heck you want with it. There’s basically a sliding scale of complexity across these CMSs. If you just want to update a couple of simple sections, then Sentry is probably the easiest, because you don’t have to worry about building the admin page. But if you want complete flexibility, then look at either of Joe’s options, Total & Easy CMS. Regardless of the choice, you’re going to get top notch support. All these guys are amazing.
