Coding Standard
Do you guys have any thoughts how you want developers to include custom styles?
Might end up in conflicts when using multiple dev-packs.
Hey @Beblebroks,
It’s always best to stick with tailwind classes where possible, it’ll ensure 100% compatibility with any other components you use, and reduce CSS.
However, it’s not always possible to do this, so when you need to use CSS you can scope a style to the instance of the component on the page using it’s id.
In the styles.css file
#{{node.id}} .heading {
    font-weight: bold;
And in the template file
<div id="{{node.id}}" class="p-10 text-lg text-center">
    <div class="heading">An interesting heading</div>
</div>
I thinking about a function you guys had years ago to obviouscate email. I am using a new CSS / JS approach to it. To avoid spam and that can not be achieved with Standard Tailwind.
.cryptedmail:after {
  content: attr(data-a) "@" attr(data-b) "." attr(data-c);
And use JS to fire the actual mailto. Works with Whatsapp as well.
Yeah ok, I think you should be able to use the same method posted above. Something like this
#{{node.id}} .cryptedmail:after {
And then use the {{node.id}} within the JS file too.
Works … awesome
