I want to change the entire background on which the stacks are placed on to another color.
How do I do that?
How do I do that?
Do you mean while you’re working on the site in Edit mode or the actual appearance of the site when you Preview it? If the latter, which theme are you using?
The actual appearance
foundry platform and foundation
I use all three depending what I am doing
not at the same time.
With Foundation, the site background is configured inside Site Styles.
If you just want a background of a container, then use a background swatch.
Thank you. This was easy and helpful. Is there a way save these for reference? It says the topic will close in a month.
Bookmark the post with the “Bookmark” button directly below “This topic will close a month after the last reply.”
@gmedlock “topic will close” simply means that folks can not add more comments if none have been added in the past 30/31 days. It does not mean the topic will be deleted or somehow become invisible.
