Columns Not Working
Might anyone be able to determine why my “2 Column” Stacks aren’t working at www.myerspoint.net? I see the “space” where the column is correctly designated, but nothing’s loading into it; the contents flow under a single column to the left.
Thanks.
-Aaron
can you explain better? I see this:
Ist that correct?
What?! That IS correct. I wonder what’s happening. I even cleared my browser cache, etc.
Hm… that said, it is indeed working now… sorry for the trouble. Maybe I panicked?
Definitely a cache issue, they don’t want to let go sometimes.
Trick: check using: private browsing/incognito window
