I can´t find any tutorial or description for costumizing the colorpicker window. I would like to increase the numbers of rows next to the colorpicker pipette. Just have two rows now.
Do you know, how I can do that?
And do you know if there is a documentation about it?
… those two rows are like one long line in a row now. I had the window fillled with those empty color fields, so I could place each saved color setting field wherever I want. this is not possible anymore with the two rows now.
Thank you a lot for your kind and quick answer, teefers!
Couldn´t find the answer in the linked text – maybe my english is too bad – but I will keep on looking on how to costumize Apple´s color picker, good advice!
Yes, I tried this, but it has not the same result as the one I had before. In your example you are extenting the row. I got a different customization before. It happened after opening a tutorial with a RW example. I forgot which tutorial that was, unfortunatelly, … But if I find it again I will tell you.
