How do I save custom colors in Color for reuse?
That can be found through the Apple Support or the Apple OS help tab.
Create a new color profile (rapidweaver?) and save it.
This is a useful App also, Sip, that I found suggested here
you can create custom palettes if you click on the 3rd icon in the top row.
A + sign appears and a new list will carry the name “unnamed palette”. You can then drag the picked colour into the palette. I recommend naming it instantly, either with a functional name (“link hover” or something) or, better, with the hex code. This will allow you to re-use the same colour where you can’t use the built-in color picker.
@therealmf It is possible that I do something wrong, but when I click on the 3rd icon
in the top row, I do not get any plus sign. I’ve tried to add color, but when I start RapidWeaver again, it’s all gone.
I think I figured it out, but getting this error when I click on the plus sign:
Something’s wrong with RapidWeaver.
- I get to create a new color palette with name.
- I save the project.
- When I open the project, the color palette is gone.
Yes. Looks like something’s wrong, but how do I fix this?
I found a solution. The Colors folder was missing in Big Sur.
~/Library/Colors´
