jabostick
(Jason Bostick)
19 January 2019 20:07
1
Does anyone know if there’s a way to change the of the ‘Close’ text in the Lux theme by @MultiThemes ? So it would have, for example, MENU in white, and then CLOSE in blue. Any CSS for that?
You can see the theme demo here:
https://www.multithemes.com/examples/lux/banner_options/
klaatu
(klaatu)
19 January 2019 20:21
2
Hey jabostick
Based on the demo page and if I understand you correctly that you just want to change the color of the text for the ‘CLOSE’ state to be blue (or whatever):
#drop.boxopened:after {
color: blue !important;
Hope thats what you were meaning.
HI @jabostick this is the code
#drop:after , #drop .boxopened:after,
#drop [class*=“icon_plus_alt”] {
Right! however we have to add also the icon code.
klaatu
(klaatu)
19 January 2019 20:29
4
@MultiThemes
Yep! That will give a nicer aesthetic than just changing the string.
jabostick
(Jason Bostick)
19 January 2019 20:56
5
Awesome, thanks @MultiThemes and @klaatu ! Works great, but that’s also changing MENU to blue as well…
I’m just heading out the door but have included a rough demo of my own in case my settings are off somewhere… https://www.jbostick.ca/test/scotian/
Thanks again
klaatu
(klaatu)
19 January 2019 21:05
6
Hi Jabostick
Not sure where its coming from but you have an earlier !important on a selector which is preventing the CSS provided by @MultiThemes from working. Did you try adding some CSS of your own and not remove it? I think its this:
#drop:after, #drop.boxopened:after, #drop [class*=“icon_plus_alt”] {
color: rgba(31,38,46,1.00) !important;
jabostick
(Jason Bostick)
19 January 2019 21:33
7
Thanks again. I’ll take a closer look when I get back home.
jabostick
(Jason Bostick)
20 January 2019 17:13
8
So here’s what I have in my project file:
The color there is just the dark navy from their logo. The only other thing is a snippet from the theme docs to hide the logo.
you can use the DEMO project ( available in the DMG file). Also this page is avialble with all Extracontents.
jabostick
(Jason Bostick)
21 January 2019 15:15
10
Thanks. I did grab the demo’s but haven’t been able to open them (they may be RW 8.1 and I haven’t upgraded to the beta yet).
Any thoughts on the CSS that I have included? Is there a way that I can get the ‘MENU’ text to stay white and only change the ‘CLOSE’ text?
klaatu
(klaatu)
21 January 2019 17:42
11
What happens when you remove your existing additional CSS and use only what I provided?
/* change only CLOSE text color /
#drop [class =“icon_plus_alt”] {
this is the code to customize the text content
/* text BUTTON content */
#drop:after {content:“MENU”;}
#drop .boxopened:after{content:“CLOSE”;}
jabostick
(Jason Bostick)
21 January 2019 18:13
13
You guys rock! The extra > #drop:after, was what was getting in the way. Thanks again
@jabostick glad you solved.
BTW: In LUX you can use RGBA colours with alpha channel, a further option to mix colours.
system
(system)
Closed
21 February 2019 08:20
15
