Franz
(Franz Rathmair)
26 September 2020 13:14
1
I am testing S4S’s Commentsstack. Font and line height of the write-review-button is too small so I want to change it via CSS.
Here is the stack’s page: https://prohomine.rathmair.de/Feedback/
I tried this CSS code, but to no avail:
#stacks_in_9_page32 .write-review-button {
font-size: 2rem;
line-height: 2;
Can anyone help me? Thanks a lot.
indridcold
(Indrid Cold)
26 September 2020 14:37
2
line-height: 2rem !important;
font-size: 1.85rem !important;
Franz
(Franz Rathmair)
26 September 2020 15:05
3
So thankful for your help!
Can I ask for your help for two more buttons. I tried but there the codes are different and I am at a loss:
I also want the Cancel button bigger as well as the Send button.
What you tried isn’t going to work because the element that has the class write-review-button doesn’t have the ID stacks_in_9_page32.
I tested this in google’s inspector. It looks like this will work, …
div#stacks_in_9_page32 button.btn {
font-size: 2rem;
line-height: 2;
I don’t like having to put the div selector there, but button.btn
on its own doesn’t seem to want to work.
Anyway, as a bonus it catches the other two buttons that appear when you click the feedback button. I’m pretty sure you’d end up wanting them too.
This stack is from @willwood . Maybe he’ll have a better suggestion.
I tried button.btn
and .btn
, something keeps getting left out.
indridcold
(Indrid Cold)
26 September 2020 16:31
5
Try:
.btn-primary, .btn-secondary {
height: 4rem !important;
font-size: 2rem !important;
background-color: rgb(0,107,128) !important;
padding-left: 22px;
padding-right: 22px;
border-radius: 4px;
color: white !important;
i.fa.fa-comment-o {
padding-left: 10px;
Franz
(Franz Rathmair)
26 September 2020 17:29
6
YES, it works! Thank you again, I appreciate your help – as well as @forbesrodney ’s answer (which I didn’t try, I admit).
system
(system)
Closed
27 October 2020 03:29
7
