Custom compoent UI controls disappear
I made an accordion CC with UI controls code in the properties section. They worked fine but after closing Elements and reopening the project file, the UI controls in the pane disappeared.
Problem solved thanks to Claude :student:. It found a syntax error in my code. The UI is back :nerd_face:
I was just about to say it’s probably a code issue… glad you got it sorted and yes, Claude is a top-notch helper :ok_hand:
