Just had issue with custom components
I dropped custom components in from one project to the next, this has worked before, this time all the code is missing
Trying again
when you copy from one project to the next they need to be pen when you save or that’s what it seems, seem previous
As I wrote most of these for practice rather than thinking ahead, I learnt quite a lot now
I tried putting my 3d spinning cube in the animation border component, one is percent the other pixels, need to change them both
First time I have tried grids so not finished that part
So put sinning cube with Elements logo inside at bottom
there are box circle triangle and multi clip path components as well
https://we.tl/t-Du5iFGgmMK
This is a known issue, copying Custom Components/Globals will not work between projects — they’ll break when you re-open the project, as it’s still referencing the other project.
This will be fixed in an upcoming beta. Stay tuned!
