Custom Component Props Not Exposed to Template (`$props` Always Empty) — Elements v1.2.2
Dear Elements-team,
I believe I’ve discovered a fundamental issue with Custom Components in RapidWeaver Elements (v1.2.2), and after lots of testing and elimination, I’m pretty sure this isn’t user error!
Summary:
No matter what properties I add to my custom component (text, number, toggle, resource), none are available via $props in the HTML template. Not even a simple text property shows up, and even <pre x-text="JSON.stringify($props, null, 2)"></pre>shows absolutely nothing. This makes building dynamic custom components impossible.
Steps to Reproduce:
  1. Create a new project and add a Custom Component.
  2. Use this properties.json:
  "groups": [
      "title": "Test Props",
      "properties": [
        { "title": "Texty", "id": "texty", "text": {} },
        { "title": "Numbery", "id": "numbery", "number": {} }
  1. In the HTML template, add:
<div x-data>
  <div>Text: <span x-text="$props.texty"></span></div>
  <div>Number: <span x-text="$props.numbery"></span></div>
</div>
  1. Fill in the Inspector fields and go to Preview. Nothing is rendered (values don’t show, JSON is empty).
I also tested with images (“resource”), arrays, and Boolean toggles (which don’t appear at all in the inspector). No data shows up in the template for any property type.
What I Expected:
That $props would contain (at minimum) the values from the Inspector for text, number, toggle, and resource fields—just like in almost all custom component/documentation examples.
What Happens:
$props is empty. Can’t render anything based on component properties. Only static HTML works.
Am I missing a trick, or is $props just not wired up in custom components currently? Maybe it is even the wrong parameter name?
If this is a known issue, is there any ETA or workaround?
If not—please consider this a high-priority bug report! This makes most interactive custom components impossible.
Thanks for your help,
Hans
Tagging @dan, @tpbradley for dev wisdom!
Hey there, thanks for the detailed post. I’m hoping I can solve this for you very quickly…
I hope I’m not stating the obvious, but you need to define the props in the hooks.js file. Here’s a screenshot of a custom component showing the hooks file (see screenshot):
Here’s a link to the hooks.js documentation with a little more information.
Does that help?
It is worth noting that not all properties from the properties file need to be processed through hooks.js; any properties that create Tailwind classes, such as a color, can be applied directly in the HTML.
You don’t access the control properties via $props.propName - you need to use {{propName}} instead.
so in your template you would do this:
<div>Text: {{texty}}</div>
<div>Number: {{numbery}}</div>
Have you had a look at the Elements language docs? There’s more info and some examples in there, but do give us a shout if you get stuck :slight_smile:
Thank you all… the {{propName}} hint helped me further.
For simple components (e.g. text, number) this is the magic andit is not even necessary to have a hooks.js.
However I will have to take a dive into the suggested Elements Manual sections.
