On my About page, I have a divider. Under that I have 3 columns across (2 contain text and 1 image between). Under that I have an image (my logo). As it is now, if you don’t scroll down the page, you don’t see the logo. So I want to decrease the space between the logo and the columns. The only margin is the 3 columns which is set to 80 (from the top). The logo is just an image. It’s not in a column. I tried putting it in a column but I still couldn’t get it closer. The site went live yesterday. consciouscounseling.net.
The problem is the image itself is stat large. It just appears that there’s margin or padding because the logo has a white background. This is what the logo image looks like:
if I add a background color to the page you can see that the image is not really spaced far below the columns above:
Yes, I was going to the say the same as Joe.
You need trim the white space above and below your logo…the actual image itself.
I had similar thing happening and it’s just a matter of cropping your image in Preview.
Cheers Scott
Thank you! Thank you!
Sincerely,
Robin Traiger, LCSW
Conscious Counseling
A New Way to Expand
THIS EMAIL AND ANY FILES TRANSMITTED WITH IT ARE CONFIDENTIAL AND ARE INTENDED SOLELY FOR THE USE OF THE INDIVIDUAL OR ENTITY TO WHOM THEY ARE ADDRESSED. This document may contain information covered under the Privacy Act, 5 USC 552(a), and/or the Health Insurance Portability and Accountability Act (PL 104-191) and its various implementing regulations and must be protected in accordance with those provisions.
If you are not the intended recipient or the person responsible for delivering the email to the intended recipient, be advised that you have received this email in error and that any use, dissemination, forwarding, printing, or copying of this email is strictly prohibited.
If you have received this email in error, please return immediately to the sender and delete this copy from your system. Thank you for your cooperation.
