Use case: I’m building a popover-style component where the “Caret” toggle should be unavailable when the user sets the popover’s background opacity below 100% — with any transparency, the caret would have visible seams against the popover edge, so I’d like to lock the switch to prevent users from enabling a feature that won’t render properly.
I’d expect the switch to be permanently greyed out / non-interactive. Instead, it remains fully toggleable — enabled appears to be silently ignored on switch controls. Same behavior with any expression I try ("true", "false", or comparisons against other props).
What I’ve ruled out:
properties.json builds cleanly, no warnings
RapidWeaver fully closed and reopened (no inspector schema cache)
visible expressions work correctly on the same component, including with responsive prop values (e.g. "caretEnabled == true && contentBgOpacity < 100" correctly shows/hides info text per-breakpoint)
A few questions:
Is enabled supported on switch controls? The docs state it works “the same way as visible”, which suggests yes.
If yes — am I missing something in the syntax?
If no — could the docs note which control types it’s supported on? And what’s the recommended pattern to conditionally lock a switch state based on another property’s value?
When myOpacity is a non-responsive slider, the switch correctly greys out as the user moves the slider below 100.
Possible follow-up issue I noticed while testing: enable doesn’t seem to react to responsive prop values, while visible does.
Same expression, two different behaviors:
// This DOES update per-breakpoint when myOpacity is responsive
"visible": "myOpacity == 100"
// This does NOT — switch stays in the same state regardless of which breakpoint dot the user edits
"enable": "myOpacity == 100"
When myOpacity is responsive ("responsive": true), I’d expect both to evaluate the value at the current breakpoint and update reactively. visible does (info paragraphs show/hide correctly when I move the value below 100 at any breakpoint). enable keeps the switch in its initial state.
Is enable perhaps using a different evaluation path that doesn’t yet handle responsive props? Could it be aligned to match visible’s behavior in a future update?
In the meantime my runtime already handles this correctly via JavaScript (reads computed alpha and skips rendering when transparent), so this is just a UX nicety — but it would make the inspector feedback more consistent.
