I have been using the Engineer Theme which I really like, nice and clean. However I have an issue on the home page.
At the bottom it has large white space and what looks like a partial divider. I would like to put another logo center of this space, how can I do this.
Or I would like the Banner to meet the dark footer
Ok got that sorted out, have added some sidebar text which is on the Left hand side. The area to the right is blank, how can I get a picture into it.
The instruction video from RapidWeaver use a different theme and this are is used by the Site Logo on their video. On this theme it puts the logo top left.
The logo is positioned by the theme. So with Engineer it goes to the top left.
What kind of page type are you using? If it’s Stacks, then you’ve got thousands of options (or maybe hundreds) when it comes to positioning elements. If it’s a Styled text page, you’ll have to work a little harder to position the logo exactly where you want it.
Also, the Sidebar in Engineer appears under the main content area so I’m not sure what you mean by “have added some sidebar text which is on the Left hand side”
Any page can be a Stacks page, including the home page. Just create a new Stacks page and then right-click and make it the home page. I’m not on my Mac, but the item in the context menu should be apparent.
Teefers, thanks you a star. Yes I had been playing around with the settings, I have reset it back to your settings and bingo the Sidebar is in the correct space. I have added some pictures but I have a line above the pictures, shown here in red in the picture. I have changed the colour to see if I can identify the line but it never changes. I would like to remove it so that the picture in the sidebar is more central.
