Exception while exporting site
Keep getting the following message when I try to update or publish a site. This worked fine earlier this week. The only thing new is a new version of RW. Currently running 6.2.3. Didn’t have this problem before.
Any help is appreciated.
  • +[NSString stringWithCString:encoding:]: NULL cString.
Are you running the OS X 10.10.5 beta?
Thanks,
—Nik
I’m getting the same error and am running 10.10.5 beta. I presume it is the problem and not Rapidweaver?
An update: http://community.realmacsoftware.com/t/os-x-10-10-5-beta/611/1
Thanks!
—Nik
Hi Nik,
That fixed the issue. I went ahead and reported the issue to Apple as well since it seems that the error is theirs.
Thanks for your help!
Apple have recently banned those running beta versions of OSX from reviewing software on the App Store for the same reason.
