So I have just added a flex inside a component, and I can’t use it ride-away, I tried to add both text inside the flex but it just doesn’t work.
I’t will only work if I save, quit elements and launch it again, then the flex works as it should and I’d be able to drag my texts inside the flex as usual.
By The Way, Is there a main component that when modified it makes changes to all other components, something like what happens in the main, changes the others. If there is! how do I identify the main component to change?
