Overlapping contents in Flex
Hello, Im new to Elements. Im fairly ok with Rapidweaver.
I have a question. Im trying to overlap an image and text in a flex box.
I have the image first, centred. Then the text and the flexbox in a column format. I set the text top margin to -100px. It shows correct in the viewing window but we i view in browser the text is underneath the image. The flex box is in a container.
edit… Ive also tried with flex…just a container, also in a background element. The same result.
The display shows what i want but the preview in browser doesnt.
Thank you.
Chris
not sure if this is what you were trying
Its kind of right but the items are off differnt widths.
Here is the image of the app…
https://imgur.com/a/eLBZ4qI
and this is the result in the browser.
Thanks again.
Can you share the project via Elements Cloud? We can then take a look and show you how to get the layout you want :slight_smile:
Yeah…i’ll give it a go. its really a test project to recreate my website i made in Rapidweaver with Foundry 3 as a way of getting to know Elements.
elementsapp://downloadDocument/ySvt9gCarMol
Is that what you need?
The rapidweaver site is at www.seriouslycollins.com
Chris
is this what you need
project here
elementsapp://downloadDocument/qbeodcpieBxW
I reset the flex image and text and then just used the transform on the text component
Yeah…i think thats spot on.
Thank you.
the only issue will be responsive size of text
I changed the image to px and changed text for each screen size
https://share.cleanshot.com/w7Ksgm87jgmX7j5TGwBV
Hi Steve, Thank you…i just worked that out too…change by break point but also translate by % seems to do it also.
Thank you so much for your help.
Lots of ways to do it
