Foundation 6: Scroll speed with On Page navigation
I am using the Dropdown Stack of Foundation 6 for On Page Navigation at https://test.ecco-network.com. The actual scroll speed is too fast for my purposes. But the Scroll Speed Setting doesn’t seem to have any effect even if I set it to an extreme value.
Any idea what’s wrong?
Regards
Prodrive
I wonder if this would work? This is from the Zurb Foundation site. 500 is the default, see if changing it does anything.
https://get.foundation/sites/docs/smooth-scroll.html
Thank you. This works just with putting in the values,
In my case it’s an advantage that I can set the time for every link seperate.
There is some kind of conflict with the Dropdown and the smooth scroll libraries. I will file a bug. It works great on a normal Menu stack.
