Foundry built ecommerce site, ready to use?
I’m looking for a ready built foundry ecommerce template (ecwid run) if poss. Or the basic structure of one, that I can update easily, preferably not using any extra code in the background, that could need changing. This has been on my to do list for the past 8 months, and I just can’t find the time to build one, with the rest of the work I have on. So I’m looking for a short cut if possible with a template. Does anyone know of any companies selling one? …or even any individuals that would be willing to sell me a ready made template. (within a reasonable cost of course :grin:)
Thanks Jon
egomade.com has lots of templates for Foundry, as does webdeersign.com , though they’re not specifically for e-commerce. There are a couple of RW projects that are e-commerce projects using RapidCart Pro (this for example: https://www.bitweb4u.com/demo/foundry_shoe_store/).
If you want an Ecwid one, the theme/project isn’t going to give you much direction as you just embed your Ecwid store on the page - the design/setup is all done in Ecwid, not RW. In that case, you could just pick an egomade project you like, and embed your ecwid store on one of the pages.
Thanks for the reply Pete (email) and Jason above. I should have really said, I’ve got a good number of files from both webdeersign and egomade (great stuff, but not really what I’m looking for), and I‘ve had a play with Ecwid. (hence leaning towards that, but not committed) i was looking to see if their was anything else out there, or if a developer/individual had a ready made one to sell. Thanks for the link to bitweb, thats much more as to what I was looking for as a starting block, I‘d not heard of them before. I just need to check out Rapidcart Pro again.
Thanks :+1:
