Is there a way to bring a web design made on Sketch app to Rapidweaver? I can tell upfront that is no way to convert one to another so don’t misinterpret my question. I want to know if a client bring me a website layout design made in sketch can I re-make it or be able to create what he want in RW?
I don’t see why not, using stacks and one of the available frameworks such as uikit, foundry, platform, source, etc. Without seeing the design, you may need a 3rd party stack
Unfortunatly you can’t import a Sketch design into RW. You have to recreate the design as a RW page (as far as I am aware, and I use both applications for some time now)
If the client uses Sketch templates similar to the one you use to create the page in RW, this might a bit of help for you, e.g. the client uses a Bootstrap template for his design and you use Foundry to recreate the page, so the building blocks are more or less the same.
There are some tools that allow to export a Sketch design to HTML or some other prototyping tools, but this is nothing RW can import.
I think Sketch devs need to know about this. Rapidweaver is a tool I use all the time.
