Should FTP upload be working correctly in the current beta? I remeber I saw something in one of the latest beta notes.
I am curently having maasive problems publishing sites with the beta…
Version 7.0 (17407b)
Works also not for me.
Today’s build should fix this - Version 7.0 (17429b)
Start your update engines or grab it from here: https://dl.devmate.com/com.realmacsoftware.rapidweaver/beta/RapidWeaver.zip
BOOM! I can publish again. However, its a lot slower than it used to be. Maybe its just my connection today…
I am pretty sure that its uploading 1 file at a time instead of 6 which I have set in the RW Prefs.
Side Note: I miss the days when it said what file it was currently uploading. Could that be brought back?
Side Note 2: I have notification center messages when publishing is complete. But I also have to click to OK button in the dialog box in RW. Can this redundancy be stopped?
More bad news… my changes are not actually getting published. I added a video to this page but its not getting published at all…
Does re-publish all files fix it?
Nope. I have done that 3 times…
I’m wondering if the page isn’t being marked as “dirty”.
If you make a few other changes or change other pages, does it work?
Can we see a quick video?
Hey Joe,
Can you try clearing the destination first and then re-publishing?
Here you go… https://infinit.io/_/D3WqHcc
renamed the file… no go…
Thanks man! Helps a ton!
Can you send us a copy of your support logs please Joe? Just make sure “Enable Upload Logging” is checked in the prefs and you’ve made some changes and published again.
Cheers
Thanks man, if you relaunch RapidWeaver does it work?
Where do I find the logs?
Restarting RW does not help.
Here is the output from the console…
4/26/16 10:39:32.684 AM RapidWeaver 7[35373]: error: 1 is not a valid value for addInit
4/26/16 10:39:33.354 AM RapidWeaver 7[35373]: open on /var/folders/ky/9c92pqyd56lfd7k5fn3njqj80000gn/T/com.realmacsoftware.rapidweaver/stacks-FDE98E45-B893-43D2-BC16-D13954527180-XLsTMC/bgImage_1285.jpg: File exists
4/26/16 10:39:35.520 AM RapidWeaver 7[35373]: Trying 69.163.176.39...
4/26/16 10:39:35.556 AM RapidWeaver 7[35373]: Connected to dreamhost.joeworkman.net (69.163.176.39) port 22 (#0)
4/26/16 10:39:35.557 AM RapidWeaver 7[35373]: Connected to dreamhost.joeworkman.net (69.163.176.39) port 22 (#0)
4/26/16 10:39:35.561 AM RapidWeaver 7[35373]: Connected to dreamhost.joeworkman.net (69.163.176.39) port 22 (#0)
4/26/16 10:39:35.562 AM RapidWeaver 7[35373]: Connected to dreamhost.joeworkman.net (69.163.176.39) port 22 (#0)
4/26/16 10:39:35.789 AM RapidWeaver 7[35373]: SSH MD5 fingerprint: f5b7da8261a9772f70afb2c353ced711
4/26/16 10:39:35.792 AM RapidWeaver 7[35373]: SSH MD5 fingerprint: f5b7da8261a9772f70afb2c353ced711
4/26/16 10:39:35.798 AM RapidWeaver 7[35373]: SSH MD5 fingerprint: f5b7da8261a9772f70afb2c353ced711
4/26/16 10:39:35.835 AM RapidWeaver 7[35373]: SSH authentication methods available: publickey,password
4/26/16 10:39:35.837 AM RapidWeaver 7[35373]: SSH authentication methods available: publickey,password
4/26/16 10:39:35.852 AM RapidWeaver 7[35373]: SSH authentication methods available: publickey,password
4/26/16 10:39:35.871 AM RapidWeaver 7[35373]: Initialized password authentication
4/26/16 10:39:35.871 AM RapidWeaver 7[35373]: Authentication complete
4/26/16 10:39:35.873 AM RapidWeaver 7[35373]: Initialized password authentication
4/26/16 10:39:35.873 AM RapidWeaver 7[35373]: Authentication complete
4/26/16 10:39:35.875 AM RapidWeaver 7[35373]: Initialized password authentication
4/26/16 10:39:35.875 AM RapidWeaver 7[35373]: Authentication complete
4/26/16 10:39:35.888 AM RapidWeaver 7[35373]: Initialized password authentication
4/26/16 10:39:35.888 AM RapidWeaver 7[35373]: Authentication complete
4/26/16 10:39:36.045 AM RapidWeaver 7[35373]: Could not open directory for reading: No such file or directory
4/26/16 10:39:36.045 AM RapidWeaver 7[35373]: Connection #0 to host dreamhost.joeworkman.net left intact
4/26/16 10:39:36.059 AM RapidWeaver 7[35373]: Could not open directory for reading: No such file or directory
4/26/16 10:39:36.059 AM RapidWeaver 7[35373]: Connection #0 to host dreamhost.joeworkman.net left intact
4/26/16 10:39:36.063 AM RapidWeaver 7[35373]: Could not open directory for reading: No such file or directory
4/26/16 10:39:36.063 AM RapidWeaver 7[35373]: Connection #0 to host dreamhost.joeworkman.net left intact
4/26/16 10:39:36.067 AM RapidWeaver 7[35373]: Could not open directory for reading: No such file or directory
4/26/16 10:39:36.067 AM RapidWeaver 7[35373]: Connection #0 to host dreamhost.joeworkman.net left intact
4/26/16 10:39:36.074 AM RapidWeaver 7[35373]: Could not open directory for reading: No such file or directory
4/26/16 10:39:36.074 AM RapidWeaver 7[35373]: Connection #0 to host dreamhost.joeworkman.net left intact
Make sure “Upload Logging” is enabled, then “Copy Support Logs”, paste it into a document and send it over to us
I did that but nothing was on my clipboard. I assume that its the same data from the Console log.
Anything else that you guys need from me on this?
Not at the moment, we’re working on it!
