Setting the grid columns for Mobile also sets it for SM. If I set the grid columns to 2 for SM it also updates Mobile - the two sizes appear to be locked for grid columns, despite overriding with a blue dot for SM?
Actually, I think the issue is to do with scroll bars. If you select the SM icon, it doesn’t appear to be allowing for the vertical scroll bar. If you manually edge the editor window a bit larger it then changes to two columns.
If you start in Mobile and then drag the editor window wider, the icon will change to SM but the grid columns will remain at 1. Dragging the Editor window slightly wider (by the width of the vertical scroll bar) will then go to 2 grid columns.
