unfortunately I have noticed a weird behaviour again. See video.
When I am in sm view, 2 images appear in a row. This is the intention. By switching to md all 4 images should be in a row. Just as it is the case in the lg view. But this only works when I switch from lg to md. From sm to md there are still 2 images in 2 rows.
And one more question. Is it possible to embed Font Awesome icons in text? If so, how?
I think you have everything set up correctly. It looks like the scrollbar appearing and disappearing is causing issues. Are you using build 22909 of the beta?
If you preview in the browser and resize the window, I’d imagine it shows the right number of grids at each breakpoint.
Have you trued uploading your site to a test folder on your server so you can view on your mobile and device and check it’s correct?
I’m using version 22909 and you’re right, it’s the scrollbar. I really should have noticed that, but unfortunately I only observed the weird behaviour.
