HELP! RW project is not opening
Hi all,
I have been working on a project using “Foundry” PS: Foundry is not my issue! and today I have tried to open the project and just couldn’t. As we all know when you click on a project and if the theme is missing it will tell you that it will apply Offend them, fair enough. My issue is that I can not even apply that theme to open it and then change to my theme.
Any advice how can I retrieve my project??
Snapshot attached.
Thank you!
Looking behind your error msg windows… why do you have a Shape Theme and Stacks folders on your desktop? Those need to be in a RapidWeaver folder. Did you pull them out? What version of RW are you using?
@1611mac I just purchased the Shape theme for another project, I will add Theme to RW folder later :slight_smile: Thanks!
As for my issue, I am using RW 7.2.2 and Foundry after downgraded from 7.3 since it gave me too many issues!
Hi @monica.
Can you zip up your project file and send it to support@realmacsoftware.com please?
It’s quite straightforward for us to fix, assuming nothing else has gone wrong with your project.
I will send via email! thank you!
Thanks, we’ve got the project and @simon is looking into it now!
Thank you @dan everything is working perfectly now!
