Help with Joe's SEO helper stack
Hi Paul,
That is great work…well done!
I’m just getting my head around SEO Helper.
Can I ask if you used the Basic stack or did you find it better to use advanced individual components to build up your meta tags?
Thanks for any advise you can offer.
Cheers Scott
That is awesome!!! It would be great is you made this as a new testimonial post on the forum. :wink:
Google can be a bit slow… they look good to me now.
I am not sure where you are getting this URL, but it does not work…
http://www.timstephens.co.uk/blog/sitemap_index.xml
Ok thanks Joe.
Oh didn’t notice I’d copied that wrong! :confounded: Is
Thanks again!
Tim
@joeworkman Happy to place the post wherever - which forum would you like me to post it into?
Paul
Hi @scottjf
My workflow is that I have what I call “Generic SEO Structured Data Tags” that will apply to all pages on my site and include organisation and website data.
Next > Social Media OG SEO tags for Facebook & Twitter for each page individually
Next > Canonicals - Robots - Breadcrumbs - Page Descriptions for each individual pages
Next > if appropriate I create an FAQ structured data set
Next > Sitemap creation embedding image tag details for each page individually
So as you can see I use all the tools at my disposal - it takes a lot of time and structure but structured information in the format required is precisely what search engines are looking for.
Paul
Hi Paul,
Thanks for the info…appreciated.
Can I check…??
So you use each of these individually rather than the set SEO Basics? (see screenshot below)
It seems like it’s not possible to do both as I get the SEO Helper error message Duplicate Meta Tags if I add one of these plus the SEO Basics.
I’m just trying to work out if you get better results by using the individual items rather than the set SEO Basics ones?
Joe may be able to answer this best.
Cheers Scott
Scott
The following screenshots are of just one page that houses multiple (but all different SEO stacks) followed by a Google Structured data analysis of the page.
Trust that helps.
I think @csmltd Paul’s post above is a little gold mine of useful information! Someone should sticky it somewhere so SEO Helper users can easily find it. I guess that would be @joeworkman and possibly copied to his weavers space forum?? Just sayin’ :smile:
Glad I could be of help @rojharris Roger and hope your SEO work bears fruit also.
