Hey, I am quite new to Rapidweaver. I consider it to be a great app to build your own website, however, I am quite a bit lost about how to modify the themes you got by Rapidweaver. For example, is there any option to change the image of the header or to make the head transparent? Thanks in advance!
These resources might help.
- http://help.realmacsoftware.com/hc/en-us/articles/200167061#themes
- http://www.webkarnage.net/rapidweaving/theme_ed/theme_ed.html
- http://seydesign.com/support/FAQ/?show=howdoimodifymytheme
What’s more this week’s podcast (#7) covered this too. Good luck!
Thank you for this quick and extremely helpful answer!
You’re very welcome, Franz!
And welcome to RapidWeaver
Each Theme is different. Headers are actually one of the more specialized things to do. But simple once you’re familiar with the way RW works.
Ben and Dan of RealMac explain the main things that you might want to try first in the podcast; I’d start there if I were you. Try changing a font or two; some colours.
Do feel free to come back here with the Theme you’re working with. Someone is sure to be able to help. Good luck!
