How do I add a svg icon before text
Hi, I’m creating a price list, and want to add icons on the left of text, such as green ticks, shields etc.
I can’t work out how to do this, as when I try to drop an svg icon to the left of text, it goes into a new column etc.
Is there a component that makes this easier..?
Loving elements btw! 1st day playing around with it today :slight_smile:
Hi @SteveG
I would do such a list with FLEX components and put the SVG and the TEXT component in it. Like so:
Then go to the setting of the Flex and set it to Row instead of column. Now your text is on the side of the SVG
If you the want to have a list of Text and SVGs you need to put the FLEXES in a CONTAINER or a FLEX. Like here:
My example looks like below:
There is a wrapping CONTAINER then a Header and then my list of FLEX with SVG and text.
Hope that helps
Thanks for taking the time to explain.
I can see from looking at your themes, that you’re a bit of a legend at this!
