Hope this is the right place for my question, if not, feel free to replace it.
I have a website build by RW. How can I create https? Now its only http.
I am a starter so please be not to complicated
Maybe this is useful for you: https://rapidpages.de/blog/post/rapidweaver-ssl-integration
It works! Thank you very much!!
Yes, but please don’t forget to redirect http to https. You have to look into the cPanel (some web hoster do auto redirections) or you have to create a .htaccess file in your root directory with some code.
You might also find this guide helpful here:
https://blog.realmacsoftware.com/remove-not-secure-rapidweaver-https/
Thanks! Greatings Barend
