Any stack suggestion:
https://hitfilm.com/ignite-express
The icons mouse over effect.
Also I need to create links on each icon.
Thanks,
Ulisses
Thanks,
Ulisses
No idea? Looks quite simple on mouse over.
@ulisses You might want to have a look at Hover Box from @willwood. The demo shows images only, but it has many uses. You can download a free demo to see if it’s suitable. https://stacks4stacks.com/hoverbox/
Thanks, I downloaded the demo but it didn’t worked for the effect I’m looking for.
The scale effect is bringing the layer from 0 to 100, not scaling it up just a little, like 30%.
Ulisses
