Am new to RW and updating a site. Getting confused!!
I have an mp4 hero home page using “impact”, this runs ok. However, I need three transparent captions/headers to drop-down seperately over time. Can I do this using “impact”? If yes how, or do I need another stack. The three seperate captions need to kinda slide down and stay in position.
Am using Foundation.
rob
Impact includes a second stack called Impact Animate.
Just select ‘Add Content’ in settings and a stack ‘well’ will appear over your video. You can now drop an Impact Animate stack into that and then add your header/caption. Add another two Animate stacks in the ame way and then add headers/captions to those. Then you can play with the animation direction, speed, start time to get the effect you’re after.
Thanks so much for the reply, your suggestion works, however I cant get the depth / centred that I need. Will go back and try again. Am using Foundation and the Impact stack, yes. Need more control of the depth and speed of decent from the top.
All the captions glide down from the top, over an mp4 movie. As you can see, need a good depth and to allow timeing for each caption to glide into position. Attached is just a “still shot” of what I need. Have been searching today and cant find anything to suit my needs. Unless, I hope you know better.
Rob
