acer4x
(Elizabeth Gentile)
November 19, 2019, 3:28pm
1
Hi - I am using RW7 and would like to have a full width banner using an interactive 360 (html5). Can I import or display this in the banner area? The 360 is in an html page similar to this: https://www.egstudios.us/tours/stamfordct/StamfordMuseum/gallery.html
These pages are normally embedded with an iframe for viewing on a website.
Many thanks,
Elizabeth
MrMacvos
(Marc Vos)
November 19, 2019, 4:42pm
2
jabostick
(Jason Bostick)
November 19, 2019, 4:44pm
3
If you’re using a theme, it may not be possible (or at a minimum, be theme dependant).
If you’re using a blank framework (like Source or Foundation, for example), then you would be able to do that
acer4x
(Elizabeth Gentile)
November 19, 2019, 9:46pm
4
Thanks for your reply Marc. This is almost what I am looking for. It is missing a couple things…
auto rotation and banner size full width display (?). Also, there is a limitation on # of panos per page which does not fit my plan.
Thanks again!
Best,
Elizabeth
acer4x
(Elizabeth Gentile)
November 19, 2019, 10:58pm
5
Hi Jason,
I think you may be correct about a blank framework but I would like to avoid that if possible. The html stack does work in Foundation for this effect.
I just thought that an extra content stack with the iframe stack might work and…it works perfectly. I am testing with the Show Theme.
Thanks for your thoughts Jason!
Best,
Elizabeth
