Is there a way to bring in an existing website?
Is there a way to import an existing website that was not created with RapidWeaver to use as a starting point for an update?
Joe Workman makes a stack called OffSite
Not all sites will work, some sites will not allow them to be imported to another site. Google and Apple are just two.
Thanks, I will give it a try.
Here are two more options in addition to JW’s. I’ve found sometimes one may work better than the others depending on the site you’re importing. All three are good options though.
http://www.defligra.com/layout-stacks/niceframe-stack/
https://stacks4stacks.com/embed/
