I’m moving forward because this error doesn’t seem to appear in any browsers so far, but I do get this error when previewing in Rapidweaver. MOST of the audio stacks that I attempt to use cause this error to display when previewing, including ones that I’ve enjoyed for a long time (Doobox BOOM, and Woodgate’s Playlister, and others).
Is this cause for concern?
Thanks!
-Alex
EDIT: The website I’m creating uses Workman’s Foundation framework…
JavaScript Errors Found: Parts of your webpage may not be fully functional.
The following errors should be addressed.
• TypeError: undefined is not an object (evaluating ‘audio.readyState’) (1x)
Adding the Legacy Query Support feature in Site Styles may fix this. See FAQ
You can look at the browser’s dev console for more details about these errors.
This error will not be displayed on your published site. Click to close
I’m quite sure this is no cause for concern. Did you already try what is suggested in the message? "Adding the Legacy Query Support feature in Site Styles may fix this". There is a swatch for this in the Site Styles of Foundation 6.
I’m not seeing a place for that in the Site Style/Swatch. I do see something in the “Super Duper Hella Advanced” section at the very bottom of the site styles stack called “Disable Preview Checkers”
That removes the error message at least, though I’m not sure it’s “fixing” any potential error.
