I am looking for a solution to this problem, and I turn to the wisdom of the Forum.
I have several academic papers posted on one of my websites. They are made up of mostly text. At the end is a series of “Figures” [images, text, audio playback].
What I would like to do is to make a link in the text the would open up a pop-up in which I could place the appropriate stacks [images, text, and audio playback].
I have used anchor tags, but that is awkward.
I want the web page to remain static in the background as a new, sized window opens up on top. The window should be able to be closed by clicking an X in the corner.
I know there are stacks that can launch pop-ups, but I need the pop-ups to launch by clicking on a short text snippet [i.e., FIGURE 1] within a large paragraph.
If you look at the site below, you will see what I am talking about. Throughout the text there are references to the Figures at the end.
I use the latest versions of RapidWeaver, Stacks and Foundation.
Thanks for the suggestions. I went with Reveal Lightbox since I had it. And it seems to be doing the trick. I will look into the other suggestions and see if they provide anything more that seems interesting. Bt for now, I’m up and running.
