I’m using @joeworkman match height stack - works perfectly until I put the columns in Elixir’s Animagic stack. Guess there’s a JS conflict.
Anyone using Match Height successfully with a different animation stack? Needs to be an animation stack that works generically with RW and not a framework specific one.
It depends on what you are trying to animate. If you are animating content inside of Match Height that affects the actual height that MH is trying to calculate, then there may not be much that you can do about it.
