If you select the foundry columns stack and select ‘equal height columns’ then provide a background color for each of the cols, you’ll see that they are indeed the same height:
Furthermore if you then take that columns stack out of the JW Match height you’ll see they remain equal height without being enclosed in the Match Height stack - the Foundry stack can do this by itself.
I suspect that what you are looking for is the content inside to more aligned?
What I am looking for is the line at the bottom of the column to be even - I thought it would be if I equalized the height of the columns. Maybe I just need to place that line somewhere else?
Unless you target the line to the bottom of it’s parent (column) it will end up relative to the content above it. I prefer the aesthetic without it; what does it add?
