A little question,
Is it possible to set all selected cookies by default in Multi-Select Consent Popup?
In this way, when opening the cookies, they are all selected and accepted, then and if one wishes, deselect the cookies that he does not accept. I think it’s better this way.
Grazie.
Yes there is an option on the child stack “Multi Select Checkbox”, near the bottom to “Start Checked”.
It does warn that this may breach privacy laws in some countries, because you are assuming consent, rather than explicitly asking for consent to be granted.
Found it, thank you very much.
Unfortunately it does not work, even if selected at startup, cookies are blocked, instead clicking on select all, then it works perfectly … maybe a little bug?
Fixed in the latest Build
