In BETA 34 the mobile and sub-menu preview option appears to not be working. I cannot get it to display the preview.
Wondering if it’s an index/layering issue… do you have your menu set to fixed or sticky?
preview doesn’t work for me either, new project drop in standard and try to use preview doesnt work, no settings changed
Mine is set to FIXED. I did try changing the FIXED to NONE, but it still did not work. Also tried setting my Z index to NONE and it still did not work.
doesnt show for me neither
@handshaper @Godber, can you share a project showing this issue? we can then get it fixed up for the next beta. Thanks!
Here is a project that has the standard menu added, without making any changes to it, and it has this problem.
one from me just add standard menu
