My site is redirecting!
I published a site today and all looked good (still working on it) Here
Sometimes when I go to it it’s there, other times its redirected to example.com
How is that possible!?
Your site redirects when using http: but its fine when using https: so you need to ask your web host to adjust the address the http redirects too.
Hope that helps :slight_smile:
Cheers
Doug
Did you add an htaccess rule to redirect to https? You might have forgotten to change the example.com to your URL.
ahhh thankyou I did forget to change it ! Thanks !
Some easy .htaccess instructions for that can be seen here:
Thanks everyone.
Yes I had remembered to edit the htaccess… but forgotton to put the domain in there. All makes sense now.
