Nick Cates: Project Depth
Can’t say I’ve seen this issue. Take a look at the Orbit demo pages on an iPad and see if that’s OK
SuperFlex 3 is my go-to slider solution: https://nickcatesdesign.com/preview/rapidweaver/superflex_3/
Just wondering If anyone has tried some form of pop over text within the depth sections ?
I just downloaded PopDrop from BWD and trying to get my head around how to use it within project depth.
I want to be able for people to click on a word ie, “grief” and get a definition or explanation as a popover content.
Has anyone successfully done this within the pre-defined depth sections?
I had some limited success doing this. You need (or at least I needed to in my tests) to write HTML in the depth text field in order for it to work. Doing it via the link dialogue box didn’t work for me.
I’m attaching a screenshot from a previous support ticket/discussion but I haven’t explored in much detail
Thank you Jason for your input. That is helpful experimentation. I can’t see the entire code you wrote in the “Sub Text” section. Would you mind posting this code snippet?
Yep, I believe this is what I have:
<a href="mailto:example@email.com" data-pop-drop="pop-email">email us</a>
Obviously, ‘pop-email’ would be replaced with whatever your popdrop ID is
Hi
How would I get a button or text (eg Phone number) into the navigation bar - as per the theme example site showing buttons to “Get Depth”?
See here: https://nickcatesdesign.com/preview/rapidweaver/depth/theme/
Sorry for the late reply, but here’s how…
https://nickcatesdesign.com/#depth > Tutorials > Upper Right Nav Button
