Please provide a few details in the following format so we can help you as quickly as possible!
RapidWeaver Version: 6.3.1 (15010)
System Version: 10.10.5
Hardware: 27-Inch iMac , 8GB Memory.
Issue:
Sometimes when I paste header code into the appropriate tab on a page, the dialog greys out. If I save, shutdown RW, then re-open, the the header code displays as it should. So the code is going in there just fine, it just seems that it requires a re-start in order to display the code properly under the header tab (page info).
Expected Result:
The code pasted into the Header tab should just display as required once pasted.
Additional Links:
