The docs ay there should be a {{page.resourcesPath}} in rw.page.
But it’s not present? See attached image
Obviously some other stuff missing as well, and published seems incorrect, as it isn’t .
const logAllProperties = (obj, depth = 0) => {
if (depth > 5) return;
Object.keys(obj).forEach(key => {
const value = obj[key];
if (typeof value === 'object' && value !== null) {
console.log(' '.repeat(depth * 2) + key + ': {');
logAllProperties(value, depth + 1);
console.log(' '.repeat(depth * 2) + '}');
} else {
console.log(' '.repeat(depth * 2) + key + ':', value);
console.log('Logging all properties of rw.page:');
logAllProperties(rw.page);
Okay, we’re looking into this one now…
@Doobox This should all be fixed and updated in Today’s Build, along with a new example component…
There were quite a few things amiss in Elements, and in the manual too - some of it was just old and needed to be tidied up.
Some things to note:
The docRootPath is blank if you’re on the home page. For other pages you’ll get a relative path to the site root. I believe this is the correct behavior - let me know if you foresee any issues here.
I’ve updated the docs to reflect all this, Available Data | RapidWeaver Elements Docs
