Partial Questions
I just started with rapidweaver last year. I love the partial features and have created quite a number of them. Unfortunately, I haven’t been very organised. After creating more than 10 partials and 30-40 pages later, I realised things are getting a bit disorganised. And I haven’t been naming the partials properly and they all started with names like “Partial 1”, “Partial 351”, “Partial 537” etc.
Is there an easy to check for a particular partial, which are the pages that are using them? Instead of going through the pages one by one?
Thank you,
Aik Pin
There isn’t a way right now to discern what pages a partial is used on. Maybe file a request to @isaiah for Stacks 4.
You can always make things a bit easier for yourself by devising a meaningful way of naming partials (you can rename those partials that you already have).
But send a request to Isaiah anyway.
Feature request noted and logged: https://github.com/yourhead/s4/issues/45
Hi Isaiah,
Yes indeed this would be a very useful feature :slightly_smiling_face:
Cheers
Thank you. Will do that.
Yes, silly of me for not doing that earlier. :sweat:
