Reuse of partials
Hi
I have just finished a migration project from iWeb to RW6, and in that process I have made a bunch of partials. In the next project that I am just starting I would like to reuse some of the partials made in the former project.
Is that possible? And if yes, how to do :slight_smile:
Yes, click on the partial and copy and paste it to the new document. Works great.
Thanks,
After a few tries I have got it working.
Thanks a lot :slight_smile:
SteveB: A really good habit to get into, if you tend to use the same partials on all sites, is first create a template, with one page and all the partials you want on it. Save it as a template, then use it as the starting point for all new projects. It’s how i work with Foundation projects.
Thanks SteveB for the great suggestion! Just what I was looking for.
Although that’s a practical and easy workaround, I’d still like Stacks to add the feature of “Duplicate” Partials within a project in the next upgrade. It seems like reusing and modifying copies of Partials would be a natural reason for using them.
Not sure where you’ve quoted @SteveB from, but good advice anyway,
This sounds like a “stacks” feature request. You should request this on YourHeads slack page:
http://slack.yourhead.com/
Thanks, I should have better attributed Steve. It was from here:
http://forums.realmacsoftware.com/t/can-partial-be-copied-over-to-a-new-rw-site/17150/3?u=ronr
Also thanks for suggestion about feature request. Actually, I’ve always been hugely impressed by how responsive RW developers are.
