I have my url for a static google map and i placed in an html stack using href="http://maps enclosed with
but the image does not display
any help with html would be appreciated
Without seeing the code you have it’s hard to say.
When you post code on the forum you need to mark it as code. Select it, and then hit the </> button.
If you are trying to grab the map embed code from google maps you need to use the embed map option and not the link:
The code is an iFrame (not responsive).
I recalled that @robbeattie had posted this helpful link to make embedded content (including Google Maps) responsive :
You can make the embedded iFrame responsive like this : https://www.labnol.org/internet/embed-responsive-google-maps/28333/
